Information field on script lines
I 'd like to have an information field on each script line.
I use the same library and filters for finding tracks.
Because filters are not visible unless you click on that field, all script might lines look the same, which is a little confusing.
So an extra information (comment) field would be nice so on each line can comment what this line is about.
I and now I 'll make it more complex:
It will be nice to have a column on the playlist showing this information field (so you can be informed from what script line this track comes) ;)
Re: Information field on script lines
I guess I see what you mean - and I guess that should be doable.
The playlist already contains a field called 'Source Info' which might be used.
I'll take a look into it...
v3.0.13.3 now contains an additional comment column for script-lines.
The 'SourceInfo' content was also enhanced accordingly to better see where a playlist entry is coming from.
