[Tags] Double ProppFrexx Tags in MP3
sun7radio
Post by sun7radio »
As I was looking for a way to retrieve some tags used by SPL and inject them into PFOA, I've noticed that ProppFrexx sets his custom tag twice in MP3 files.
There is a 'ProppFrexx' tag and a 'PROPPFREXX' tag, both contain the same XML content.
I guess some part of PFOA is using one and some other is using the other one.
This happens only for MP3 files, I don't have this issue wiyh M4A (I only have 'PROPPFREXX' in M4A).
(I only use those two format for songs so far, so I don't know if other formats are impacted)
Not a big deal though, just for your information.
Cheers,
Guy.
Re: [Tags] Double ProppFrexx Tags in MP3
No, I don't do that!
Could it be, that your MP3 files do contain two different TAGs, e.g. ID3v2 and APE?
If that is the case, then yes, I do save the custom tag to both TAG structure to be in sync with both.
But if your MP3 file only contains ID3v2 - then I only save the custom tag once.
sun7radio
Post by sun7radio »
That must be it. Sorry again for the noise then.. )
Cheers,
Guy.
