Quick access toolbar linked to playlist ??
andrerotgans
Post by andrerotgans »
A question... Is the setup of the Quick Access Toolbar anyhow linked to a playlist ? If just say a strange thing happening. Over the last hour I've adjusted some things to my Quick Access Toolbar. Worked fine, 'till the start of a next scheduled playlist. Is switched back to its original setup.
It seems very unlogical and perhaps it was something else happening (I didn't do anything with PFOA at that moment), but I'm just wondering :)
Kind regards,
André
Re: Quick access toolbar linked to playlist ??
Yes, that is indeed currently by design ;-) the playlist buttons can not really be saved to the QAT - they are indeed lost the next time, as when the playlist it is linked from is closed those buttons are removed and as such can not be restored.
I'll see, if I can make them persistent anyhow...
andrerotgans
Ah, ok, well, the best part of this is that I'm NOT crazy and I'm not imagining things ;) I'll stick to the normal buttings in the QAT for the moment, than. I was trying out a setup for DJ's where there was a very limited amount of buttons in the ribbon and most of the used ones where in the QAT. But we'll leave that for this moment.
Thanks !
André
