First overlay plays but no sound
I 've created the slots/overlays with adv pattern wizard. For each slot I set an opener and closer track a playlist (.pfp file). That file is currently empty (no files added to it). Will add files in future.
Later I schedule for example 2 ads to play. The first one (after the opener) starts playing but without sound. The second one plays normally.
If I add a file to .pfp file, the sound is as it should.
Re: First overlay plays but no sound
Not sure what you are doing exactly. What do you mean by "Later I schedule for example 2 ads to play"? Did you reload the advert lib in PF after adding files? If not, that's the mistake.
Or Maybe you set some funky cue points or ACPD? Or some other Gain TAGs?
As I said I created the slots/overlays with adv pattern wizard and set for each slot an empty .pfp file for opener and closer track.
When that overlay/slot plays, the first spot in that slot looks like playing but has no sound. The next spots play normal.
If I add at least one track to the (empty) .pfp file (that is set for opener track) all the spots of that slot sound normal.
Yep, that seems to be indeed a bug ;-)
It happens, if the specified opener playlist is actually empty.
Will be fixed in next version. For now...an opener playlist should at least contain one track ;-)
Fixed in v3.0.12.14!
