Fixed Time Elements and Jingles
louis
Post by louis »
I have my scripts set up to play fixed time element stationIDs and also use the Jingle feature, placing a jingle every 1-4 lines of script.
Unfortunately, sometimes this means a Jingle and a StationID play back to back. Is there anyway I can have the Jingle line ignore one or all fixed time elements in the script?
Thanks
Re: Fixed Time Elements and Jingles
Yes, within a script you can define so called 'Script-Rules...' - just click on the 'Script-Rules...' button within the script editor.
Script-Rules are explained here:
viewtopic.php?f=4&t=705
Note: Script-Rules are only available in the Professional or Enterprise Edition!
