Limit the search time in find track
XTended
When a user search for an entry in "Find Track" that is spelled wrong the searching for that entry is very long.
Is there a possibility to create a limit for the searchtime? For example after 10 seconds the search request will be ended.
Regards,
Bert
Regards,
Bert
- Searching (I already deleted the search entry, but the searching continues...)
- Find-Track-Searching.jpg (18.53 KiB) Viewed 9181 times
Re: Limit the search time in find track
Not sure yet - but I'll take a look if that is possible!
XTended
Thanks for your answer.
Will it be added in a new PFOA update?
Add to v3.0.13.0!
See notes in 'News and Announcements'!
