Mute on channel
workino
Mute on channel
Post by workino »
i just reopened my radio so i play again with Proppfrexx.
I don't understand why if i try to mute an imput channel it don't be affected. :(
I would make some more test but can anyone, please, tell me if i make something wrog?
Best Regards
Workino
Re: Mute on channel
What are your input mixer configuration settings?
(double-click on the mixer channel name to open them)
Have you may be defined the same physical device multiple times (for multiple input mixer channel) or is the device may be being used by other applications in parallel (e.g. Skype or similar)?
