Add to Standby Player from Playlist
Farbo
Post by Farbo »
Bernd, would it be possible to have option (with right click menu) to add certain track also to Standby Player? This could be usefull for example if you have music track planned to be played as next but before it also jingle should be played and you want to talk over before that track and play its hook in order to attract listeners what will be played for example right after jingle.
Peter
Re: Add to Standby Player from Playlist
Yes, I can add that to the next version.
However, in the meantime you might simply drag those tracks from the playlist over to a Standby-Player.
Farbo
Post by Farbo »
OK, thank you. I did not know it is possible this way already today.
Peter
