Length of shortcut text in Cartwall
andrerotgans
Post by andrerotgans »
Just a little 'cosmetic' thing. When using a shortcut to a remote library in the cart walls, it shows the complete path to that library. So, in my case ie REMOTE:vs-winserv2012:8088/****//Algemeen
This is rather long and will not fit.
Is it an idea to use the comment instead when linking to a remote library ? Or strip the first part ?
Kind regards.
André
Re: Length of shortcut text in Cartwall
Will not fit where?
It is only relevant when selecting it and there is its always shown or hoover over it to see its full path.
However, i'll take a look at it...
andrerotgans
"Will not fit" as in will not fit in the button. Ok, when selecting it it's shown and also when hovered over, but it might be clearer for a user to see it at first sight without having to hover four buttons in order to figure out where his jingles are :-)
Fixed in v3.0.13.0 - as you can now specify a freely configurable Name for any lib.
