Strange problem with scheduler next program is day ago...
XTended
Post by XTended »
Dear Bernd,
After updating to the latest Windows .NET framwework version we've got a very strange problem, see screenshot.
At this moment its not possible to use the scheduler cause it only sees the Next program in the past: 17-12-2013 and today its 18-12-2013.
Is this a known problem after updating?
Regards,
Bert Koning
Re: Strange problem with scheduler next program is day ago..
That indeed looks funky...which .Net framework is it you updated to?...and have you restarted your PC in between?
And what ProppFrexx Version are you using?
XTended
Post by XTended »
Bernd,
Latest version of PF and latest version of .NET 4.51.
And yes we did a lot of reboots...
Bert
I can absolutely not reproduce this here on 4 different PCs running XP, Vista and Win7/8 using the same versions as you noted.
Please try to delete the *.layout files in your ProppFrexx AppUserData folders and try it again...or run a Virus Check on your PC...maybe this is causing such strange effects.
Fixed in v3.0.12.12!
