Filename A to Z within Find Track search option
XTended
Post by XTended »
When searching within the FindTrack search option I miss the A to Z option.
Re: Filename A to Z within Find Track search option
What do you mean by "A-Z option"? Do you mean a sorting option?
If yes, you can sort the find result by clicking on the resp. column header.
Hold the SHIFT key while clicking on another column header to apply a cascading sort or hold the CTRL key while clicking on the same column header to remove the sort.
A 1st click on a column header sorts the column ascending a 2nd click sorts it descending.
Else right-click on a column header to see all other options...
