Overlay Calendar in Use
Hi Bernd.
After fresh reinstall I wanted to set some things in overlay scheduler but I get this message. I suppose it has something to do with the default application folder and the fact I changed the username for windows later. How can I open overlay scheduler or what shall I do in order not to get this message?
Thank you.
Thank you.
- Overlay Calendar in Use.jpg (20.13 KiB) Viewed 8718 times
Peter
Re: Overlay Calendar in Use
No, that is a multi-user access warning.
i.e. to prevent, that a 2nd user/machine accesses/modifies the scheduler calendar, while another user already modifies it.
If you are only one user on your system - then this indicates, that the machine was somehow not properly terminated (while the lock was still set).
In such case you can press and hold the ALT+CTRL key while clicking on the Program or Overlay Scheduler calendar ribbon/menu item to unlock it!
Thank you Bernd. It works with ctrl+alt keys. But can I do something to repair this so I don´t get this warning?
Peter
The CTRL+ALT combo already did the repair!
