Incorrect window size (Win8/8.1)
szal77
Post by szal77 »
Hi Bernd
A minor niggle really, but one that annoys me. I’ve set the main ProppFrexx window to Maximized, and when I launch the software, the bottom end of the window slides under the panel a millimetre or two. I then have to rectify this by un- and re-maximizing the window, then the position is correct with the bottom window border exactly bordering the panel.
Unfortunately this position doesn’t seem to be stored on exit, and when I launch PFOA again the window is a bit too large once again.
Could you please have a look into this? Thank you very much.
Kind regards
Sven
Re: Incorrect window size (Win8/8.1)
It seems I am not able to reproduce that issue here with the latest v3.0.12.10!
With which version are you testing it?
szal77
Post by szal77 »
I am running 3.0.12.10 too.
Can you recheck this with the latest v3.0.12.12!?
