Rescan of folder based libraries at startup
Farbo
Post by Farbo »
Hi Bernd.
Automatic rescan of folder based libraries at startup is not working even though I picked that possibility in settings. Thus my scheduler is not working as all libraries are not linked then and PF can not choose from any media files to pick up into playlist.
Peter
Re: Rescan of folder based libraries at startup
That sounds like the same issue as posted before...like your ProppFrexx startup is broken...
Any errors in the "Error.log" file?
Farbo
Post by Farbo »
I can have a look on error log when I am at home. Yes, indeed it seems like some problem with startup.
Peter
I will close this thread, as I am pretty sure, that it is related to this one:
viewtopic.php?f=7&t=870
Farbo
Post by Farbo »
OK.
Peter
