Crash to deletes history
dokos
Post by dokos »
I have a problem: every two to three weeks to me that the software crashes.
I do not know where it might be wrong but always deletes history ...
Where can be a problem.
Sending image from history.
Marian
Re: Crash to deletes history
a) please upgrade to the latest version v3.0.12.6!
b) it is a graphics and Out of memory error...
dokos
Post by dokos »
5. 10. 2013 10:58:01 [v3.0.12.4]:********** Error/Exception Information **********
Error Message: Attempt by security transparent method 'DevExpress.Utils.Drawing.XtraBufferedGraphicsContext.CreateCompatibleDIB(IntPtr, IntPtr, Int32, Int32, IntPtr ByRef)' to access security critical method 'System.Runtime.InteropServices.Marshal.GetLastWin32Error()' failed.
Assembly 'DevExpress.Utils.v13.1, Version=13.1.6.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' is marked with the AllowPartiallyTrustedCallersAttribute, and uses the level 2 security transparency model. Level 2 transparency causes all methods in AllowPartiallyTrustedCallers assemblies to become security transparent by default, which may be the cause of this exception.
Error Type: System.MethodAccessException
Error Source: DevExpress.Utils.v13.1.IntPtr CreateCompatibleDIB(IntPtr, IntPtr, Int32, Int32, IntPtr ByRef)
at DevExpress.Utils.Drawing.XtraBufferedGraphicsContext.CreateCompatibleDIB(IntPtr hdc, IntPtr hpal, Int32 ulWidth, Int32 ulHeight, IntPtr& ppvBits)
at DevExpress.Utils.Drawing.XtraBufferedGraphicsContext.CreateBuffer(IntPtr src, Int32 offsetX, Int32 offsetY, Int32 width, Int32 height)
at DevExpress.Utils.Drawing.XtraBufferedGraphicsContext.AllocBuffer(Graphics targetGraphics, IntPtr targetDC, Rectangle targetRectangle)
at DevExpress.Utils.Drawing.XtraBufferedGraphicsContext.AllocBufferInTempManager(Graphics targetGraphics, IntPtr targetDC, Rectangle targetRectangle)
at DevExpress.Utils.Drawing.XtraBufferedGraphicsContext.Allocate(Graphics targetGraphics, IntPtr targetDC, Rectangle targetRectangle)
at DevExpress.Utils.Internal.DXLayeredWindowEx.DrawToBackBuffer(IntPtr backBufferDC)
at DevExpress.Utils.Internal.DXLayeredWindowEx.UpdateLayeredWindowCore(Action`1 updateBackBufferCallback)
at DevExpress.Utils.Internal.DXLayeredWindowEx.Update()
at DevExpress.Utils.Internal.DXLayeredWindowEx.UpdateAsync()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at ProppFrexx.y.a(Exception A_0, Boolean A_1)
at ProppFrexx.cx.a(Exception A_0)
at ProppFrexx.cx.b(Exception A_0)
at ProppFrexx.cx.a(Object A_0, ThreadExceptionEventArgs A_1)
at System.Windows.Forms.MdiClient.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
at DevExpress.Utils.Mdi.MdiClientSubclasser.WndProc(Message& m)
at System.Windows.Forms.Application.Run(Form mainForm)
at ProppFrexx.do.a(String[] A_0)
********** End **********
5. 10. 2013 10:58:04 [v3.0.12.4]:********** Error/Exception Information **********
6. 10. 2013 1:58:02 [v3.0.12.4]:********** Error/Exception Information **********
Error Message: Exception of type 'System.OutOfMemoryException' was thrown.
Error Type: System.OutOfMemoryException
Error Source: System.Windows.Forms.System.String get_WindowText()
at System.Windows.Forms.Control.get_WindowText()
at System.Windows.Forms.Control.set_CacheTextInternal(Boolean value)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at DevExpress.XtraEditors.XtraScrollableControl.WndProc(Message& m)
at DevExpress.Utils.Controls.PanelBase.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnThreadException(Exception e)
6. 10. 2013 1:58:07 [v3.0.12.4]:********** Error/Exception Information **********
Error Message: ScriptLib-GetNextTracks Error in '06-18 Slager mix 4 [06-18 Slager mix 4.pfs]' at line 7 [1 Random : /Koktail cz Pomale]
Error Type: System.Exception
Error Source: .
Inner Exception: Exception of type 'System.OutOfMemoryException' was thrown.
Error Source: mscorlib.System.String InternalChangeCaseString(IntPtr, IntPtr, System.String, System.String, Boolean)
at System.Globalization.TextInfo.InternalChangeCaseString(IntPtr handle, IntPtr handleOrigin, String localeName, String str, Boolean isToUpper)
at System.Globalization.TextInfo.ToLower(String str)
at System.String.ToLower(CultureInfo culture)
at System.String.ToLower()
at ProppFrexx.ai.a(gw A_0, Boolean A_1)
at ProppFrexx.ai.b(gw A_0)
at ProppFrexx.ai.a(Object A_0, DateTime A_1, DateTime A_2)
at ProppFrexx.a8.a(DateTime A_0, DateTime A_1, Byte A_2, gw A_3)
at ProppFrexx.a8.a(Boolean A_0, Byte A_1)
at ProppFrexx.a8.b(Byte A_0)
at ProppFrexx.cx.s.g()
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.ExecutionContextCallback(Object obj)
at System.Threading.Tasks.ThreadPoolTaskScheduler.LongRunningThreadWork(Object obj)
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ThreadHelper.ThreadStart(Object obj)
6. 10. 2013 1:58:12 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: DevExpress.Utils.v13.1.System.Object Clone()
at DevExpress.Utils.AppearanceObject.Clone()
at DevExpress.Utils.Drawing.SkinGroupObjectPainter.GetBorderInfo(GroupObjectInfoArgs info, Rectangle border)
at DevExpress.Utils.Drawing.SkinGroupObjectPainter.DrawBorder(GroupObjectInfoArgs info)
at DevExpress.Utils.Drawing.GroupObjectPainter.DrawObject(ObjectInfoArgs e)
at DevExpress.Utils.Drawing.ObjectPainter.DrawObject(GraphicsCache cache, ObjectPainter painter, ObjectInfoArgs e)
at DevExpress.XtraEditors.PanelControl.DrawPanel(GraphicsCache cache, GroupObjectInfoArgs info)
at DevExpress.XtraEditors.PanelControl.OnPaint(PaintEventArgs e)
6. 10. 2013 1:58:18 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: DevExpress.XtraBars.v13.1.DevExpress.XtraBars.Ribbon.ViewInfo.RibbonSeparatorItemViewInfo CreateSeparatorViewInfo(DevExpress.XtraBars.Ribbon.IRibbonItem)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonStatusBarViewInfo.CreateSeparatorViewInfo(IRibbonItem item)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonStatusBarViewInfo.CreateItemsViewInfo()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonStatusBarViewInfo.CalcViewInfo(Rectangle bounds)
at DevExpress.XtraBars.Ribbon.RibbonStatusBar.CheckViewInfo()
at DevExpress.XtraBars.Ribbon.RibbonStatusBar.OnPaint(PaintEventArgs e)
at DevExpress.XtraBars.Ribbon.RibbonStatusBar.WndProc(Message& m)
6. 10. 2013 1:58:40 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: DevExpress.XtraTreeList.v13.1.Void DrawNodeCell(DevExpress.XtraTreeList.CustomDrawNodeCellEventArgs)
at DevExpress.XtraTreeList.Painter.TreeListPaintHelper.DrawNodeCell(CustomDrawNodeCellEventArgs e)
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawCell(CellInfo cell)
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawCells(RowInfo ri)
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawRow(TreeListDrawInfo e, RowInfo ri)
at DevExpress.XtraTreeList.Painter.TreeListPainter.DrawRows()
at DevExpress.XtraTreeList.Painter.TreeListPainter.DoDraw(TreeListViewInfo viewInfo, DXPaintEventArgs e)
at DevExpress.XtraTreeList.TreeList.OnPaint(PaintEventArgs e)
at DevExpress.XtraEditors.Container.EditorContainer.WndProc(Message& m)
at DevExpress.XtraTreeList.TreeList.WndProc(Message& m)
6. 10. 2013 1:58:47 [v3.0.12.4]:********** Error/Exception Information **********
at System.Windows.Forms.UserControl.WndProc(Message& m)
6. 10. 2013 1:58:53 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: mscorlib.Void ReplaceBufferInternal(Char*, Int32)
at System.Text.StringBuilder.ReplaceBufferInternal(Char* newBuffer, Int32 newLength)
at System.Windows.Forms.UnsafeNativeMethods.GetWindowText(HandleRef hWnd, StringBuilder lpString, Int32 nMaxCount)
at System.Windows.Form m)
at System.Windows.Forms.Control.WndProc(Messages.Application.ThreadContext.OnThreadException(Exception t)
6. 10. 2013 1:59:00 [v3.0.12.4]:********** Error/Exception Information **********
Error Message: Object is currently in use elsewhere.
Error Source: System.Drawing.Void Restore(System.Drawing.Drawing2D.GraphicsState)
at System.Drawing.Graphics.Restore(GraphicsState gstate)
at DevExpress.XtraEditors.ScrollBarBase.WndProc(Message& m)
at System.Windows.Forms.SafeNativeMethods.UpdateWindow(HandleRef hWnd)
at System.Windows.Forms.Control.Update()
at DevExpress.XtraEditors.ScrollBarBase.LayoutChanged(Boolean allowDelayed)
at DevExpress.XtraEditors.ScrollBarBase.set_Value(Int32 value)
at ProppFrexx.d8.f(Int64 A_0)
at ProppFrexx.d8.ba(Object A_0, EventArgs A_1)
at DevExpress.XtraEditors.XtraUserControl.WndProc(Message& m)
at DevExpress.Utils.Win.Hook.ControlWndHook.CallWindowProc(IntPtr pPrevProc, IntPtr hWnd, Int32 message, IntPtr wParam, IntPtr lParam)
at DevExpress.Utils.Win.Hook.ControlWndHook.WindowProc(IntPtr hWnd, Int32 message, IntPtr wParam, IntPtr lParam)
6. 10. 2013 1:59:07 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: System.Windows.Forms.Void WmPaint(System.Windows.Forms.Message ByRef)
at DevExpress.XtraEditors.BaseControl.WndProc(Message& msg)
6. 10. 2013 1:59:14 [v3.0.12.4]:********** Error/Exception Information **********
6. 10. 2013 1:59:21 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: mscorlib.Void ConvertToManaged(IntPtr, IntPtr, IntPtr)
at System.StubHelpers.ValueClassMarshaler.ConvertToManaged(IntPtr dst, IntPtr src, IntPtr pMT)
at System.Drawing.SafeNativeMethods.GetDIBits(HandleRef hdc, HandleRef hbm, Int32 arg1, Int32 arg2, IntPtr arg3, BITMAPINFO_FLAT& bmi, Int32 arg5)
at System.Drawing.BufferedGraphicsContext.bFillBitmapInfo(IntPtr hdc, IntPtr hpal, BITMAPINFO_FLAT& pbmi)
at System.Drawing.BufferedGraphicsContext.CreateCompatibleDIB(IntPtr hdc, IntPtr hpal, Int32 ulWidth, Int32 ulHeight, IntPtr& ppvBits)
at System.Drawing.BufferedGraphicsContext.CreateBuffer(IntPtr src, Int32 offsetX, Int32 offsetY, Int32 width, Int32 height)
at System.Drawing.BufferedGraphicsContext.AllocBuffer(Graphics targetGraphics, IntPtr targetDC, Rectangle targetRectangle)
at System.Drawing.BufferedGraphicsContext.AllocBufferInTempManager(Graphics targetGraphics, IntPtr targetDC, Rectangle targetRectangle)
at System.Drawing.BufferedGraphicsContext.Allocate(IntPtr targetDC, Rectangle targetRectangle)
6. 10. 2013 1:59:24 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: mscorlib.Void .ctor(System.String, Int32, Int32, Int32)
at System.Text.StringBuilder..ctor(String value, Int32 startIndex, Int32 length, Int32 capacity)
6. 10. 2013 1:59:32 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: System.Drawing.Single[] get_Elements()
at System.Drawing.Drawing2D.Matrix.get_Elements()
at System.Drawing.Graphics.GetContextInfo()
at System.Windows.Forms.Internal.WindowsGraphics.FromGraphics(Graphics g, ApplyGraphicsProperties properties)
at System.Windows.Forms.WindowsGraphicsWrapper..ctor(IDeviceContext idc, TextFormatFlags flags)
at System.Windows.Forms.TextRenderer.DrawText(IDeviceContext dc, String text, Font font, Rectangle bounds, Color foreColor, TextFormatFlags flags)
at DevExpress.Utils.Paint.XPaintTextRender.InternalDrawString(GraphicsCache cache, String s, Font font, Rectangle r, Brush foreBrush, StringFormat strFormat)
at DevExpress.Utils.AppearanceObject.DrawString(GraphicsCache cache, String text, Rectangle bounds, Brush foreBrush, StringFormat format)
at DevExpress.XtraEditors.Drawing.LabelControlObjectPainter.DrawSimpleString(LabelInfoArgs le)
at DevExpress.XtraEditors.Drawing.LabelControlObjectPainter.DrawLabelText(ObjectInfoArgs e)
at DevExpress.XtraEditors.Drawing.LabelControlObjectPainter.DrawObject(ObjectInfoArgs e)
at DevExpress.XtraEditors.Drawing.LabelControlPainter.DrawContent(ControlGraphicsInfoArgs info)
at DevExpress.XtraEditors.Drawing.BaseControlPainter.Draw(ControlGraphicsInfoArgs info)
at DevExpress.XtraEditors.LabelControl.OnPaint(PaintEventArgs e)
6. 10. 2013 1:59:39 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: DevExpress.Utils.v13.1.Void OnPaint(System.Windows.Forms.PaintEventArgs)
6. 10. 2013 1:59:42 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: System.Windows.Forms.Void Invalidate(Boolean)
at System.Windows.Forms.Control.Invalidate(Boolean invalidateChildren)
at ProppFrexx.UI.PeakMeter.set_Value(Int32 value)
at ProppFrexx.e0.e()
6. 10. 2013 1:59:54 [v3.0.12.4]:********** Error/Exception Information **********
6. 10. 2013 2:00:03 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: System.Void .ctor(PERF_COUNTER_DEFINITION, System.Diagnostics.CategorySample, Int32)
at System.Diagnostics.CounterDefinitionSample..ctor(PERF_COUNTER_DEFINITION perfCounter, CategorySample categorySample, Int32 instanceNumber)
at System.Diagnostics.CategorySample..ctor(Byte[] data, CategoryEntry entry, PerformanceCounterLib library)
at System.Diagnostics.PerformanceCounterLib.GetCategorySample(String category)
at System.Diagnostics.PerformanceCounterLib.GetCategorySample(String machine, String category)
at System.Diagnostics.PerformanceCounter.NextSample()
at System.Diagnostics.PerformanceCounter.NextValue()
at ProppFrexx.cx.a(CancellationToken A_0)
at ProppFrexx.cx.aw()
at System.Threading.ThreadHelper.ThreadStart()
6. 10. 2013 2:00:16 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: DevExpress.XtraEditors.v13.1.DevExpress.Utils.AppearanceDefault GetDefaultAppearance(System.Windows.Forms.Control)
at DevExpress.XtraEditors.Drawing.LabelControlSkinObjectPainter.GetDefaultAppearance(Control ownerControl)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.get_DefaultAppearance()
at DevExpress.XtraEditors.BaseStyleControl.get_ForeColor()
dokos
Post by dokos »
6. 10. 2013 2:00:31 [v3.0.12.4]:********** Error/Exception Information **********
at System.Drawing.BufferedGraphi msg)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(MessagecsContext.CreateCompatibleDIB(IntPtr hdc, IntPtr hpal, Int32 ulWidth, Int32 ulHeight, IntPtr& ppvBits)
6. 10. 2013 2:00:35 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: mscorlib.Void Initialize(Int32)
at System.Collections.Generic.Dictionary`2.Initialize(Int32 capacity)
at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonItemViewInfo.set_Bounds(Rectangle value)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonQuickAccessToolbarViewInfo.UpdateItemsLayout(Rectangle contentRect, Int32 beginIndex, Int32 count)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonQuickAccessToolbarViewInfo.CalcFitContentInfo(Int32 bestWidth)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonQuickAccessToolbarViewInfo.CalcContentInfo(Int32 bestWidth)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonQuickAccessToolbarViewInfo.CalcViewInfo(Rectangle bounds)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonCaptionViewInfo.CalcToolbar()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonCaptionViewInfo.UpdateToolbar()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonViewInfo.UpdateToolbar()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonViewInfo.UpdateCaptionAndToolbar()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonViewInfo.CalcViewInfo(Rectangle bounds)
at DevExpress.XtraBars.Ribbon.RibbonControl.CheckViewInfo()
at DevExpress.XtraBars.Ribbon.RibbonControl.UpdateViewInfo()
at DevExpress.XtraBars.Ribbon.RibbonControl.MergeRibbon(RibbonControl ribbon)
at DevExpress.XtraBars.Ribbon.RibbonControl.OnMdiChildActivate(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnMdiChildActivate(EventArgs e)
at DevExpress.XtraEditors.XtraForm.OnMdiChildActivate(EventArgs e)
at ProppFrexx.cx.OnMdiChildActivate(EventArgs e)
at System.Windows.Forms.Form.ActivateMdiChildInternal(Form form)
at System.Windows.Forms.Form.WmMdiActivate(Message& m)
at System.Windows.Forms.UnsafeNativeMethods.DefMDIChildProc(IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.Form.DefWndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.Control.DefWndProc(Message& m)
at System.Windows.Forms.UnsafeNativeMethods.SendMessage(HandleRef hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.Control.SendMessage(Int32 msg, IntPtr wparam, Int32 lparam)
at System.Windows.Forms.Form.Activate()
at ProppFrexx.cx.s.a.b()
6. 10. 2013 2:58:00 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: DevExpress.Utils.v13.1.DevExpress.Utils.TextOptions CreateTextOptions()
at DevExpress.Utils.AppearanceObject.CreateTextOptions()
at DevExpress.Utils.AppearanceObject.get_TextOptions()
at DevExpress.Utils.AppearanceHelper.Combine(AppearanceObject target, AppearanceObject main, AppearanceObject defaultAppearance, Boolean reset)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonItemViewInfo.UpdatePaintAppearanceCore(AppearanceObject destAppearance, BarItem item)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonItemViewInfo.UpdatePaintAppearance()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonItemViewInfo.CalcBestSize()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonPageGroupLayoutCalculator.ShouldStartNewColumn(GroupColumnLayoutInfo info)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonPageGroupLayoutCalculator.UpdateGroupLayout(Rectangle contentBounds)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonPageGroupViewInfo.CalcGroupContent()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonPageGroupViewInfo.CalcViewInfo(Rectangle bounds)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonPanelLayoutCalculator.UpdatePanelLayout()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonPanelLayoutCalculator.CalcPanelLayout()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonPanelViewInfo.CalcPanelContent()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonViewInfo.CalcPanel()
at DevExpress.XtraBars.Ribbon.RibbonControl.UnMergeRibbon()
at ProppFrexx.cx.a(a8 A_0, g9 A_1, Boolean A_2, Boolean A_3)
at ProppFrexx.cx.b(Object A_0, ReminderEventArgs A_1)
at DevExpress.XtraScheduler.SchedulerStorageBase.RaiseReminderAlert(ReminderEventArgs e)
at DevExpress.XtraScheduler.SchedulerStorageBase.OnRemindersAlerted(Object sender, ReminderEventArgs e)
at DevExpress.XtraScheduler.Native.ReminderEngine.OnReminderAlert(Object sender, ReminderBaseEventArgs e)
at DevExpress.XtraScheduler.Native.ReminderEngineBase.RaiseReminderAlert(ReminderBaseEventArgs e)
at DevExpress.XtraScheduler.Native.ReminderEngineBase.RaiseRemindersAlertsCore(ReminderBaseEventArgs args)
at DevExpress.XtraScheduler.Native.ReminderEngineBase.RaiseRemindersAlerts(DateTime currentTime)
at DevExpress.XtraScheduler.Native.ReminderEngineBase.OnTimerTick(Object sender, EventArgs e)
at DevExpress.XtraScheduler.Native.LeakSafeTimerTickEventRouter.OnTimerTick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
6. 10. 2013 2:58:08 [v3.0.12.4]:********** Error/Exception Information **********
Error Message: ScriptLib-GetNextTracks Error in '06-18 Slager mix 3 [06-18 Slager mix 3.pfs]' at line 4 [1 Random : /Repete Stredne]
Error Source: .
Error Source: ProppFrexx ONAIR.Boolean c(System.String, System.String)
at ProppFrexx.ai.c(String A_0, String A_1)
at ProppFrexx.ai.a(gw A_0, gw A_1)
at ProppFrex m)
at System.Windows.Forms.Control.WndProc(Messagex.a8.b(Byte A_0)
6. 10. 2013 2:58:09 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: System.Drawing.System.Drawing.Color FromKnownColor(System.Drawing.KnownColor)
at System.Drawing.Color.FromKnownColor(KnownColor color)
at System.Drawing.KnownColorTable.ArgbToKnownColor(Int32 targetARGB)
at System.Drawing.ColorTranslator.FromOle(Int32 oleColor)
at System.Windows.Forms.Internal.DeviceContext.get_TextColor()
at System.Windows.Forms.Internal.WindowsGraphics.DrawText(String text, WindowsFont font, Rectangle bounds, Color foreColor, Color backColor, IntTextFormatFlags flags)
at System.Windows.Forms.Internal.WindowsGraphics.DrawText(String text, WindowsFont font, Rectangle bounds, Color color, IntTextFormatFlags flags)
at DevExpress.XtraEditors.Drawing.TextEditPainter.DrawString(ControlGraphicsInfoArgs info, Rectangle bounds, String text, AppearanceObject appearance)
at DevExpress.XtraEditors.Drawing.TextEditPainter.DrawText(ControlGraphicsInfoArgs info)
at DevExpress.XtraEditors.Drawing.TextEditPainter.DrawContent(ControlGraphicsInfoArgs info)
at DevExpress.XtraEditors.Drawing.BaseEditPainter.Draw(ControlGraphicsInfoArgs info)
6. 10. 2013 2:58:18 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: mscorlib.System.Object InvokeMethod(System.Object, System.Object[], System.Signature, Boolean)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at DevExpress.XtraEditors.Registrator.EditorClassInfo.CreateViewInfo(RepositoryItem item)
at DevExpress.XtraEditors.Repository.RepositoryItem.CreateViewInfo()
at DevExpress.XtraTreeList.ViewInfo.CellInfo.CreateViewInfo(TreeListColumn column, TreeListNode node)
at DevExpress.XtraTreeList.ViewInfo.CellInfo..ctor(TreeListColumn column, TreeListNode node)
at DevExpress.XtraTreeList.TreeList.InternalCalcNodeHeight(RowInfo ri, Int32 nodeHeight, ArrayList ColumnWidthes, Boolean useCache, ArrayList& cells, Boolean even, Boolean includeColumnIndent)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcNodeHeight(RowInfo ri, ArrayList& viewInfoList)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowGroupInfo(TreeListNodes nodes, CalcRowGroupInfoArgs rowArgs)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.BriefCalcRowsInfo()
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowsInfo()
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcViewInfo()
at DevExpress.XtraTreeList.TreeList.UpdateLayout()
at DevExpress.XtraTreeList.TreeList.LayoutChanged()
at DevExpress.XtraTreeList.TreeList.EndUpdate()
at ProppFrexx.a8.ak.f()
6. 10. 2013 2:58:31 [v3.0.12.4]:********** Error/Exception Information **********
6. 10. 2013 2:59:00 [v3.0.12.4]:********** Error/Exception Information **********
** m)
at System.Windows.Forms.ContainerControl.WndProc(Message******** Environment Stack Trace **********
6. 10. 2013 2:59:20 [v3.0.12.4]:********** Error/Exception Information **********
6. 10. 2013 2:59:29 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: System.Drawing.System.Drawing.Text.TextRenderingHint get_TextRenderingHint()
at System.Drawing.Graphics.get_TextRenderingHint()
at System.Windows.Forms.Internal.WindowsFont.WindowsFontQualityFromTextRenderingHint(Graphics g)
at System.Windows.Forms.TextRenderer.MeasureText(IDeviceContext dc, String text, Font font, Size proposedSize, TextFormatFlags flags)
at DevExpress.Utils.Paint.XPaintTextRender.CalcTextSize(Graphics g, String s, Font font, StringFormat strFormat, Int32 maxWidth, Int32 maxHeight, Boolean& isCropped)
at DevExpress.Utils.Paint.XPaintTextRender.CalcTextSize(Graphics g, String s, Font font, StringFormat strFormat, Int32 maxWidth)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcSimpleTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode, Int32 predWidth, Int32 predHeight)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(Boolean useHotkeyPrefix)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextPoints()
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcContentRect(Rectangle bounds)
at DevExpress.XtraEditors.LabelControl.LayoutChanged(Boolean isVisualUpdate)
at DevExpress.XtraEditors.LabelControl.LayoutChanged()
at DevExpress.XtraEditors.BaseControl.OnPropertiesChanged()
at DevExpress.XtraEditors.LabelControl.OnPropertiesChanged()
at DevExpress.XtraEditors.BaseStyleControl.OnStyleChanged(Object sender, EventArgs e)
at DevExpress.Utils.AppearanceObject.OnChanged()
at DevExpress.Utils.AppearanceObject.OnPaintChanged()
at DevExpress.Utils.AppearanceObject.set_ForeColor(Color value)
at DevExpress.XtraEditors.BaseStyleControl.set_ForeColor(Color value)
6. 10. 2013 2:59:56 [v3.0.12.4]:********** Error/Exception Information **********
Error Source: System.Drawing.System.Drawing.GraphicsUnit get_PageUnit()
at System.Drawing.Graphics.get_PageUnit()
at DevExpress.Utils.AppearanceObject.CalcDefaultTextSize(Graphics g)
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonCaptionViewInfo.CalcCaptionHeight()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonCaptionViewInfo.CalcCaption()
at DevExpress.Skins.XtraForm.RibbonFormPainter.CalcRibbonCaption()
at DevExpress.Skins.XtraForm.RibbonFormPainter.CheckReady()
at DevExpress.Skins.XtraForm.FormPainter.get_Margins()
at DevExpress.Skins.XtraForm.RibbonFormPainter.get_Margins()
at DevExpress.Skins.XtraForm.FormPainter.GetZoomedMargins()
at DevExpress.Skins.XtraForm.FormPainter.NCCalcSize(Message& m)
at DevExpress.Skins.XtraForm.FormPainter.DoWndProc(Message& msg)
at DevExpress.Skins.XtraForm.RibbonFormPainter.DoWndProc(Message& msg)
at DevExpress.Utils.Drawing.Helpers.NativeMethods.UnsafeNativeMethods.SetWindowPos(IntPtr hWnd, IntPtr hWndInsertAfter, Int32 X, Int32 Y, Int32 cx, Int32 cy, Int32 uFlags)
at DevExpress.Skins.XtraForm.FormPainter.InvalidateNC(Control control)
at DevExpress.XtraBars.Docking.DockManager.ResumeRedrawForm()
at DevExpress.XtraBars.Docking.DockManager.EndFormLayoutUpdate()
at DevExpress.XtraBars.Docking.DockManager.UpdateControlsZOrder()
at DevExpress.XtraBars.Docking.Helpers.DockLayout.OnRemoveComplete(Int32 index, Object value)
at System.Collections.CollectionBase.System.Collections.IList.Remove(Object value)
at DevExpress.XtraBars.Docking.Helpers.BaseLayoutInfo.RemoveLayout(LayoutInfo info)
at DevExpress.XtraBars.Docking.Helpers.LayoutInfo.Dispose()
at DevExpress.XtraBars.Docking.Helpers.DockLayout.Dispose()
at DevExpress.XtraBars.Docking.DockPanel.DisposeCore()
at DevExpress.XtraBars.Docking.ZIndexControl.Dispose(Boolean disposing)
at System.ComponentModel.Component.Dispose()
at System.ComponentModel.Container.Dispose(Boolean disposing)
at System.ComponentModel.Container.Dispose()
at ProppFrexx.cx.Dispose(Boolean disposing)
at System.Windows.Forms.ApplicationContext.Dispose(Boolean disposing)
at System.Windows.Forms.Application.ThreadContext.DisposeThreadWindows()
at System.Windows.Forms.Application.ThreadContext.Dispose(Boolean postQuit)
at DevExpress.Skins.XtraForm.FormPainter.CalcSizeFromClientSize(Size client)
at DevExpress.XtraEditors.XtraForm.SizeFromClientSize(Size clientSize)
at DevExpress.XtraEditors.XtraForm.ClientSizeFromSize(Size formSize)
at DevExpress.XtraEditors.XtraForm.PatchClientSize()
at DevExpress.XtraEditors.XtraForm.OnSizeChanged(EventArgs e)
at DevExpress.XtraBars.Ribbon.RibbonForm.OnSizeChanged(EventArgs e)
at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
at System.Windows.Forms.Control.UpdateBounds()
at System.Windows.Forms.UnsafeNativeMethods.DefFrameProc(IntPtr hWnd, IntPtr hWndClient, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.Control.WmWindowPosChanged(Message& m)
6. 10. 2013 2:59:57 [v3.0.12.4]:********** Error/Exception Information **********
at DevExpress.XtraBars.Ribbon.ViewInfo.BaseRibbonViewInfo.CalcConstants()
at DevExpress.XtraBars.Ribbon.ViewInfo.RibbonStatusBarViewInfo.CalcBestHeight()
at DevExpress.XtraBars.Ribbon.RibbonStatusBar.SetBoundsCore(Int32 x, Int32 y, Int32 width, Int32 height, BoundsSpecified specified)
at System.Windows.Forms.Control.System.Windows.Forms.Layout.IArrangedElement.SetBounds(Rectangle bounds, BoundsSpecified specified)
at System.Windows.Forms.Layout.DefaultLayout.xLayoutDockedControl(IArrangedElement element, Rectangle newElementBounds, Boolean measureOnly, Size& preferredSize, Rectangle& remainingBounds)
at System.Windows.Forms.Layout.DefaultLayout.LayoutDockedControls(IArrangedElement container, Boolean measureOnly)
at System.Windows.Forms.Layout.DefaultLayout.xLayout(IArrangedElement container, Boolean measureOnly, Size& preferredSize)
at System.Windows.Forms.Layout.DefaultLayout.LayoutCore(IArrangedElement container, LayoutEventArgs args)
at System.Windows.Forms.Layout.LayoutEngine.Layout(Object container, LayoutEventArgs layoutEventArgs)
at System.Windows.Forms.Control.OnLayout(LayoutEventArgs levent)
at System.Windows.Forms.ScrollableControl.OnLayout(LayoutEventArgs levent)
at System.Windows.Forms.Form.OnLayout(LayoutEventArgs levent)
at DevExpress.XtraBars.Ribbon.RibbonForm.OnLayout(LayoutEventArgs levent)
at System.Windows.Forms.Control.PerformLayout(LayoutEventArgs args)
at System.Windows.Forms.Control.System.Windows.Forms.Layout.IArrangedElement.PerformLayout(IArrangedElement affectedElement, String affectedProperty)
at System.Windows.Forms.Control.OnResize(EventArgs e)
at System.Windows.Forms.Form.OnResize(EventArgs e)
at DevExpress.XtraBars.Ribbon.RibbonForm.OnResize(EventArgs e)
at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
at System.Windows.Forms.UnsafeNativeMethods.IntSetWindowRgn(HandleRef hwnd, HandleRef hrgn, Boolean fRedraw)
at System.Windows.Forms.UnsafeNativeMethods.SetWindowRgn(HandleRef hwnd, HandleRef hrgn, Boolean fRedraw)
at System.Windows.Forms.Control.set_Region(Region value)
at DevExpress.Skins.XtraForm.FormPainter.UpdateFormRegion()
at DevExpress.Skins.XtraForm.FormPainter.WMSize(Message& msg)
at DevExpress.Skins.XtraForm.RibbonFormPainter.WMSize(Message& msg)
Error Source: mscorlib.System.Collections.IEnumerator GetEnumerator()
at System.Collections.Hashtable.ValueCollection.GetEnumerator()
Where is the problem?
Thank you for your response.
Marian
Please see the file called "Error.log" contained in the ProppFrexx AppUserData folder...any errors contained in there?
Else see the Windows Event log for any crash entries!
If you find nothing...then it might looks like a hardware issue.
However, if the PC crashes, it might be the case, that the latest (new) history entries are not saved.
