MIDI mapping options
Dolkis
Post by Dolkis »
Can you maybe ad a "set" funktion after im recording a new buttom.
Im clicking on the new buttom, changing the number from 1 to 2, record the new pad buttom, and whant to set it, and it wont work.
Fix it plz?
Re: MIDI mapping options
?I am afraid I don't know what you looking for?!
In the midi mapping dialog the NEW button is use to add a new mapping entry whereas the SET button is used to update the currently selected one.
Can you please describe a bit more in detail what your issue is.
Dolkis
Post by Dolkis »
If you want to edit one Midi setting, you cant record a new buttom then click on the Set buttom to set the new recordings.
But you can click on the New Button instead?
I still don't really get it.
Dolkis
Post by Dolkis »
Go in to the Midi mappings, change the recording for a thing you already have fixed. You cant click on set, you must click on the new one, and then Delete the old one.
So when Im mapping my Launchap I must do like this,
First i need to click on NEW, then I change the cartwall from 1 to 2, after that I record the buttom on the launchpad (Know I want to press set) instead I need to click on NEW, and then Delete the other one above.
Should now be fixed in v3.0.12.7!
