Cardwall 2 new things I want
Dolkis
Post by Dolkis »
Cardwall countdown in Timecode, we are using a launchpad and wont have the cardwalls upp for display.
(want to keep it clean and simple in the studio)
Can you maybe add upp to 50 cardwalls in the Midi controller settings?
Thanks for the awesome program! =)
Re: Cardwall 2 new things I want
I'll take a look for the cardwall countdown.
One issue I need to look at is the priority (as a playlist item might be playing at the same time and a standby-one as well...)
But something might be done.
Regarding the cartwall Midi commands:
I guess you mean adding related control-commands?
However, please take a look to the following commands, which already allow you to specify a <cartid> as its parameter and as such I guess no extra commands needs to be added, as the cartwalls itself doesn't have any count limit.
CW1/2_PLAY_CART
CW1/2_PLAYONLY_CART
CW1/2_STOPONLY_CART
CW1/2_FADEOUT_CART
CW1/2_FADEOUTSLOW_CART
CW1/2_FADEOUTFAST_CART
CW1/2_CART_ISPLAYING
CW1/2_CART_ISLOOPED
CW1/2_CART_LOOP_ON
CW1/2_CART_LOOP_OFF
CW1/2_CART_LOOP_TOGGLE
CW1/2_CART_PFL
CW1/2_SELECT_CART
CW2_CART_KEYSTATE_TOGGLE
Dolkis
Post by Dolkis »
Nop, I cant get this to work over 30.
CW1_PLAY_CART_31,32,33,34,35 is not working.
Have tested on two diffrent installs and no one is working.
Please see the User Manual appendix...
It is NOT the CW1_PLAY_CART_31 command - but the CW1_PLAY_CART command !
Example:
CW1_PLAY_CART 31
This will do the job! Notice, that it is not the command with the underscore, but with a single parameter!
In the latest v3.0.12.7 the cardwall countdown can now be displayed in the TimeCode window.
Dolkis
Post by Dolkis »
Yes its working know, Launchpad is aweseome for the cartwall!
And very nice with the cartwall countdown! :)
One more thing, we have jingles with intros in. Can that be imbeded to you think?
Dolkis wrote:One more thing, we have jingles with intros in. Can that be imbeded to you think?
Not sure what you mean.
Can you explain this again in a bit more detail...
Dolkis
Post by Dolkis »
In the cardwall countdown I cant se the countdown for the Intros.
(intro1,intro2,outro) I hope you understand what I meen.
I have beeds with jingles in them so we can only speak for about 20-28 sec.
I have a problem with my Launchpad, I want the buttoms to blink and I can make it work without the underline " _ "
After 30 I can use the underline, the commands dont understand without the underline.
Yes, the Intro, Intro2 and Outro are currently not part of it (you didn't request that initially).
A good example by the way, why a detailed requirement is important.
I'll put that in the wish list for a future release...
Regarding the control-commands: Are you talking about the control-command "CW1_PLAY_CARD" or are you talking about the macros "${cw1cartXXisplaying}"?
If the latter, note that the cartwall play state macros currently range from 01 to 30 - meaning there is currently no direct support for more than 30 carts within the macros.
Also note, that the macros have been renamed recently from "${cw1cardXXisplaying}" to "${cw1cartXXisplaying}"!
Dolkis
Post by Dolkis »
Yeah thanks man!
Yes its the later one, to bad. Can you maybe fix that? =) If you do my launchpad will blink while playing a Jingle =)
