PFL Player -> Hook settings -> Item inserted into playlist
andrerotgans
Post by andrerotgans »
Don't know wether it's a bug or a feature, but we noticed that after setting hook-points using the PFL player and leaving it in 'hook mode', that track will be inserted as a 'hook' in the playlist. So, if you set hookpoints and forget to turn back to normal mode, every time someone else searches for this track and inserts it into his/her playlist, it will only play for the hook part. I can't seem to find any indication in the searchresults that it is in hook mode ?
Don't know what happens when this track is inserted via a script.
Kind regards,
André
Re: PFL Player -> Hook settings -> Item inserted into playli
Yes, this is currently by design.
But while thinking about it, I guess that might be changed in the next version, since you are right, by default you don't want this.
I'll take a look to it...
In v3.0.12.6 you will now be asked, if you want to restore the original play mode (HOOK/NORMAL) if you changed it within the PFL Player.
