Input
grebda
Input
Post by grebda »
Hi I have a problem in version 3.0.12.4! Always after about 20 minutes longer work input to the mixer! So you must delete the entry and create a new one! What is wrong?
SORRY FOR MY VERY BAD ENGLISH !! :-( :-(
Re: Input
Please use v3.0.12.5 and try again...
However, that sounds like a soundcard/driver issue:
- what soundcard
- what mixer input channel settings are you using (driver model, buffer etc.)
- routing/copy to settings
- silence detection enabled?
A bit more details are needed.
Also what do you mean by "...no longer work input..."?
Can you explain this in a bit more details? Is the audio stopping? Is the app crashing?
Re: Input
Seems to be closed?!
