Version 3.0.12.00 Reported As Virus!!!
RedPanda
Post by RedPanda »
I wanted to let you know while installing this version of ONAIR, Avast Antivirus is detecting your instal as a virus. I've not had this problem before when updating so I thought I should let you know. Here is the info the antivirus spewed out:
Infected File:
FileName: ProppFrexx Time.exe
Virus Description: Win32:Evo-gen
I tried to report it as a false positive.
RedPanda
Re: Version 3.0.12.00 Reported As Virus!!!
Post by RedPanda »
Ok Cool! Thanks! I figured so. Just wanted to tell you just in case, or someone instals it and the antivirus deletes the file. At least you will know why.
I double checked this with various Antivirus software packages (among other with Bitdefender and Avira) - all did not found a virus!
So this is definitely a false positive of Avast!
