closing running unscheduled playlist
toidi
Post by toidi »
is this a bug ???
or i don't now how to set it .
new scheduler entry (when started) don't closing running unscheduled playlist
(It stops, but stays opened).
A program scheduler entry (when started) does the following:
- it opens a new playlist window
- assigns the given 'Script' to that playlist window
- and starts to AutoPlay this playlist at the defined start time
- stops/closes any previous running playlist
Re: closing running unscheduled playlist
This behavior is by well design!
A new program entry open/starts a new playlist window but (only) closes those playlist windows, which also have been opened/started by the scheduler.
As such playlist windows which have been manually opened, must be manually closed - there might be good reasons, why you opened a playlist window manually.
