Invalid Parameter
DennisdeWit
Invalid Parameter
Post by DennisdeWit »
Hi there,
I want to record every single hour with ProppFrexx. So, I wanted to do a control command:
Action: MIXER_INPUT_REC ON:
Parameter: Line 3 (Breakaway Pipeline)|E:\test.mp3
But it only errors. ERROR: invalid parameter (must be valid mixer name or index).
It seems like I've put it an incorrect parameter. But I don't know how to make a proper one. Any help on this?
Thanks,
Dennis
Re: Invalid Parameter
Each ProppFrexx mixer channel has a name (as configured in the mixer channel configuration settings, up to 5 characters long).
This name is also being shown in very bold letters above each mixer channel...you need to use that name in your control-commands.
So your command must look something like this:
MIXER_INPUT_REC ON MIC1|E:\test.mp3
DennisdeWit
Yes, but I would like te record the sound of BreakAway, not the input of my USB audio card (which is assigned to INP)
I have no idea what you configured as a mixer channel...
However, you can of course only record a configured mixer channel.
So if you haven't configured the Breakaway as a mixer channel yet, simply do so...
