v3.0.11.48 - stable
v3.0.11.48 - stable
Version 3.0.11.48 is out!
What's New?
  • No Sound Device support added
  • PlayNext bug-fix (when close to end-of-track)
  • Overlay Mixing optimized/enhanced
  • Program Mixing optimized/enhanced
  • Template Wizard (Resolve Overlays/Skip empty Entries) option added
  • Audio AddOns are now selectable (enable/disable)
  • Other smaller bug-fixes
  • stable
In the mixer output channel configuration you can now select the NONE driver model and specify 'None' as the 'Output To' value.
This allows you to specify a real no sound device output channel - e.g. to be used in a server environment without any soundcard present.
Program/Overlay Mixing optimized/enhanced
The 'Mixing Time' defines the mix time in milliseconds between two programs/overlays (which is the overlapping time of the last track of the previous playlist and the first track of the next playlist/overlay).
When a new script is started 'Soft' the first track of that script is played this milliseconds before the last track of the current script is cued out.
Set to 0 to start the next program with the 'Next' cue-point of the last track of the previous script.
When the program/overlay is started 'Fixed' the fade-out time is by default determined by the mixing settings of the current playing track of the playlist and this value defines the segue (overlapping) time. But when using a negative value this will now define a fixed fade-out time!
This new template option allows you to suppress adding empty overlays when resolved as playlist entries.
You can now select/deselect (enable/disable) certain audio add-ons - see general settings.
