Changing lincence to usb
Andreas Duswald
Post by Andreas Duswald »
Hello Bernd
I read, that you will be away from the 15th of may for some days. We will get a new computer and have to transver PF during that time to the new Mashine. Is it possible, that i change my licence now to an USB Stick, and then run PF on the new mashine with this USB registering?
If this is possible, how do i have to do this?
Thanks for Advice
Everything is possible ....
Re: Changing lincence to usb
Yes thats possible, I'll contact you directly.
Andreas Duswald
Thanks for the quick help - All worked fine - Have a good time away from the work :-)
