Velleman command to start DJ player
mikedude
Post by mikedude »
I'm using command PLS_CURRENT_PLAYPAUSE_A and it works, but I'm not sure it's the correct command.
Because when I set the Cue point is another position and then press the hardware start button, it starts the corresponding track but with a fade in. So the volume is not set to 100% at the moment it plays.
Am I doing anything wrong?
Re: Velleman command to start DJ player
Then you might use the PLS_CURRENT_PLAYPAUSENOFADE_A command.
The regular Play/Pause function starts playing the track using the 'Fading' option (which is by default turned on).
Which means a track is faded in/out accordingly.
The above (NOFADE) command starts/stops the track immediately without any fading.
