Talk User Settings problem
Zidago
Post by Zidago »
I am having an issue with the talk user settings for all accounts I have set.
After setting it up so that the TalkUser sets TalkOver box checked, Stop Playlist (AutoPlay) box checked and then set the drop down box to eject the current playing track, the program works exactly as it should.
After resetting the PC though the drop down box that is set to Eject the Current Playing Track gets changed back to "Nothing" and our announcers have a nasty surprise when they go to talk sometimes where even though the song is supposed to eject, it keeps playing but puts on the microphones.
I have fixed this with commands:
PLS_CURRENT_AUTOPLAY_OFF
PLS_CURRENT_EJECT_CURRENT
MIXER_INPUT_MUTE_OFF MIC
and the opposite for talk user off. But since this is a bug I thought I should report it and hope for a fix.
Also, any word on the script location for the actual files?
Re: Talk User Settings problem
Oh yes, I see the issue...it will be fixed with the next release!
What do you mean by "any word on the script location for the actual files"?
Zidago
Post by Zidago »
Thanks Bernd.
I was talking about an email I had sent about the location of the scripts and the thin client PCs always resetting the location of where they saved them to a local file on the PC and not on a network location as indicated on the script save path location.
That last script file location is already preserved in v3.0.11.47!
Should be fixed now in v3.0.11.48!
