ACPD: Factor In Metadata Gain Adjustment
szal77
Post by szal77 »
Good morning Bernd,
One thing that has been long bothering me about PFOA is that when setting ACPD cue points, it does not adjust these for gain adjustments. So the cue points for a given track are always set at the same position, no matter whether I crank the gain up, turn it down, or leave it as-is.
In my opinion, it would be desireable for the ACPD algorithm to keep the Gain setting in mind when calculating cue points.
Example:
In Mixing/Fading, I have defined Cue-in and Cue-out to be set at −79 dB, and Next at −30 dB. Now, if I adjust the Gain for a track by, say, +3 dB, these points should then automatically be set at −82 and −33 dB, respectively. Concurrently, if I adjust the Gain to, say, −2 dB, these points should be set at −77 and −28 dB, respectively.
A similar adjustment could be made when using ReplayGain (which I don’t, so I don’t know whether that is not already the case).
I hope you understand what I mean. :)
Kind regards
Sven
szal77
Re: ACPD: Factor In Metadata Gain Adjustment
Post by szal77 »
I do have 3.0.11.45—can you tell me where that option is, please? :)
szal77
Post by szal77 »
Seems to work as expected. Thank you. :)
If you haven't updated to the latest v3.0.11.45 already - pls do so, since this option should be included in that version now already ;-)
For ReplainGain there is already an appropriate option existing in the general settings (see General/Audio).
The initial track gain is now automatically been considered in the ACPD.
Uups, sorry, I meant v3.0.11.46!
The initial track gain is automatically considered (no option needs to be set).
For ReplayGain it is the 'Use ReplayGain in ACPD' option!
