Excluding is not excluding?
DennisdeWit
Post by DennisdeWit »
I'm excluding Announcements and Sweepers from the FILE_WRITE info. I checked it at 'More Stuff'. Since the upgrade to v3.0.11.45 it doesn't seem to work anymore. Did it change? Do I do something wrong?
Thanks,
Dennis
Re: Excluding is not excluding?
What do you mean by "FILE_WRITE info" ?
The "Exclude" Filter in the "More Stuff" section of the general settings relates to the Playback History - and a quick test here revealed, that this filter is working just fine.
So may be you are looking to something different?
DennisdeWit
I used the Exclude Filter at 'More Stuff'. I'm using the following eventscript to create the now playing file:
EXEC_WRITE_FILE
X:\2.txt|nd|${cpltrackartistcurrent} - ${cpltrackartistcurrent} - ${cpltracktitlecurrent}. But it keeps showing sweeps too, even when I exclude them at the More Stuff section.
DennisdeWit
It wasn't a bug. I just was too silly. Never noticed the 'Exclude' tab at the Eventmodule. Fixed.
