ONAIR Watcher
Farbo
ONAIR Watcher
Post by Farbo »
Even when I normally closed PF and ONAIR Watcher is set not to restart PF at normal termination, it was restarted. :-( This is how Watcher logged the steps.
09.05.2012 23:00:06 INFO: ProppFrexx ONAIR Watcher started.
09.05.2012 23:01:08 WARNING: ProppFrexx ONAIR has terminated abnormally or was killed! (BUT PF WAS CLOSED NORMALLY)
09.05.2012 23:01:08 INFO: Restarting C:\Program Files\radio42\ProppFrexx ONAIR\3.0\ProppFrexx ONAIR.exe
Peter
Re: ONAIR Watcher
That sounds really strange - are you sure that PF was really closed normally?
And is this happening always or only sometimes?
As far as I remember you already had such funny situation on your machine a copuple of month ago.
Farbo
Re: ONAIR Watcher
Post by Farbo »
I closed it normally (upper right corner). I had this situation months ago but we did not find any solution for this. Maybe it has something to do also with the fact PF process still hangs in system processes after PF window closed.
Peter
Farbo
Re: ONAIR Watcher
Post by Farbo »
Bernd, I am still experiencing the same problem. Maybe someone here could advice why PF hangs in sysstem processes for a long time (up to 10 minutes sometimes) after it was closed. I think if I solve this problem, OnAir Watcher would also behave normally.
Peter
