players - mixer bag
toidi
players - mixer bag
Post by toidi »
proppfrexx starts with "SND" "on" (checked, blue) ("OUT" out) ...
i turn it off ...
when i use "PFL Player" (or "Segue-Editor") and after i close it,
"SND" is "on" again ...
Re: players - mixer bag
Probably you have defined the "AutoSND @ No PFL" functionality with the mixer channel?!
Make a right-click onto the SND button and check the "Auto SND" sub-menu to see, if the "No PFL" option is selected.
If yes, uncheck it - resp. select 'Off'.
Since, if 'NO PFL' checked - this means SND is automatically (re)activated once any pre-fade-listening mode ends (e.g. by closing the PFL Player or the Segue Editor).
toidi
Post by toidi »
it was that ...
"No PFL" was "on" ...
i put this in a "bugs" section because i didn't turn "Auto SND" "on" ...
it appears after updating to v3.0.11.40 ...
tnx
An update wouldn't have changed any mixer settings...so it must have been accidentally enabled or via the Mixer-Setup-Wizard...
