‘Preserve’: Strangeness when Stopping/Resuming Playback
szal77
Post by szal77 »
Just playing around with the new auto-load-tracks-on-drop functionality. It mostly works as expected, but I’ve already found some things that don’t look like they should…
I had inserted Track 2 while Track 1 was already playing in Deck A and tracks 3 and 4 were loaded in Decks B and C, respectively. Then I hit F4, so playback paused after Track 2. After hitting F4 again to resume playback, the above situation ensued. I then hit F4 again to pause playback after Track 3 would have been finished. And then, when again hitting F4 to resume playback, I had this…
To my surprise, Track 3 was also loaded in Deck A, and even though already marked as played, it played again!
As you also see, at this point there were only 2 tracks marked as loaded in the playlist. It normalized again (showing 3 tracks as loaded) when continuing playback without pausing.
So there’s something in the bushes here; the question is, what is it…
Kind regards
Sven
Re: ‘Preserve’: Strangeness when Stopping/Resuming Playback
I guess I see what the issue might be...it'll be fixed soon!
Should now be fixed with the new v3.0.11.41!
