Remote control-SW
grebda
Remote control-SW
Post by grebda »
Hello! What do some. Exe file, that through it we can from another computer connected to the basic functions PropPfrexx (Palylist, Mixer, Find, Seque) so we could operate the radio anywhere on the PC
SORRY FOR MY VERY BAD ENGLISH !! :-( :-(
Re: Remote control-SW
I am not sure, if I understand you correctly - but it seems to me, that you are looking for a tool (.exe) which allows you to trigger remote control-commands towards ProppFrexx.
Is this correct?
If yes, note, that this already exists - it is located in your ProppFrexx ONAIR installation folder and is called "pfremcmd.exe".
It allows you to send any control-command to any ProppFrexx instance.
Just execute it to see the command-line options and how it works...
DennisdeWit
Post by DennisdeWit »
What about something as simple as RealVNC?
Oh, you can use VNC, TeamViewer, RemoteDesktop etc. with ProppFrexx, no problem...
