VT not working on remote?
DennisdeWit
Post by DennisdeWit »
I use a Media Library using the Remotefunction. I can play every song and use them in a Segue Editor. But the VoiceTrack function is not working. It just says both decks are empty (and they don't generate a waveform).
The MediaLibrary path is: \\SERVER\Tracks\
Might this be a bug?
Thanks,
Dennis
Re: VT not working on remote?
I'll double-check this...
Yes, now I see where the problem is...a new version will soon be available, fixing this issue!
Can you explain a bit more in detail what you mean by "use a Media Library using the Remotefunction"?
What kind of MediaLib is it - folder-based, playlist-based...a remote media library accessing a media library server...?
Also what audio format does the tracks have (mp3, wav, ...)?
And how did you start the VT - note, that the tracks should not be loaded to any DJ Players yet and that you should start VT on the first one.
DennisdeWit
It's a remote media library accessing a media library server. I've put \\PC\E\TracksFFM as folder, which contains MP3. Segue Editor, everything is working, except VoiceTrack.
I solved it by do not using a remote media server, and add a network folder, linked to a virtual harddrive.
Should now be fixed in v3.0.11.40!
