XP: blue screen
DennisdeWit
XP: blue screen
Post by DennisdeWit »
So, I wanted to transport ProppFrexx from Windows 7 to Windows XP (which supports MBL4 sound processing; Windows 7 doesn't). I use Virtual Audio Cables as virtual soundcard. In Windows 7, ProppFroxx works like a charm with the VAC.
But at Windows XP, it gets me into the Mix Setting Wizard. I just put in VAC as play-out. Then Propfrexx started, and ta-daa: a blue screen. I tried it again, but again, the infamous blue screen. Why does ProppFrexx doesn't work with XP and VAC's?
DennisdeWit
Re: XP: blue screen
Errorcode: error code 100008e
DennisdeWit
Re: XP: blue screen
After 'initializing audio engine', I get the blue screen. Even with a freshly installed Windows XP.
Re: XP: blue screen
As said, that sounds like a bug in one of your soundcard drivers...as they are initialized at this point.
Re: XP: blue screen
Sounds like an XP driver issue and not a ProppFrexx one.
The error code is a general unexpected exception - typically reported by device drivers...
