Error after installation
Farbo
Post by Farbo »
Hi Bernd.
What could be the reason for this error mesage when launching PF after installation?
3.3.2013 12:05:33 [v3.0.11.35]:********** Error/Exception Information **********
Error Message: Value does not fall within the expected range.
Error Source: System.Windows.Forms.Void Navigate2(System.Object ByRef,
System.Object ByRef, System.Object ByRef, System.Object ByRef,
System.Object ByRef)
at System.Windows.Forms.UnsafeNativeMethods.IWebBrowser2.Navigate2(Object&
URL, Object& flags, Object& targetFrameName, Object& postData, Object&
headers)
at System.Windows.Forms.WebBrowser.PerformNavigate2(Object& URL,
headers)
at System.Windows.Forms.WebBrowser.set_Url(Uri value)
Peter
Re: Error after installation
can you post me the full error.log, as this seems to be only a partial fragment of the full error.
But it like some invalid URL has somewhere been specified...
Farbo
Post by Farbo »
Sorry Bernd, I can not send you more now because this error appeared on my colleague´s machine. :-( I will try to look at his computer through remote desktop session and if this error persist, I will send it to you.
Peter
Farbo
Post by Farbo »
Bernd, here is the complete error message. Could this be it is because this computer has WindowsXP and .Net Framework 4.0?
It was fresh installation of frame network and PF too.
5.3.2013 10:40:38 [v3.0.11.35]:********** Error/Exception Information **********
Error Source: System.Windows.Forms.Void Navigate2(System.Object ByRef, System.Object ByRef, System.Object ByRef, System.Object ByRef, System.Object ByRef)
at System.Windows.Forms.UnsafeNativeMethods.IWebBrowser2.Navigate2(Object& URL, Object& flags, Object& targetFrameName, Object& postData, Object& headers)
at System.Windows.Forms.WebBrowser.PerformNavigate2(Object& URL, Object& flags, Object& targetFrameName, Object& postData, Object& headers)
at ProppFrexx.ck.b()
at ProppFrexx.ck..ctor()
at ProppFrexx.cy.cf()
at ProppFrexx.cy..ctor(f A_0)
********** End **********
Peter
Should now be fixed in v3.0.11.36!
However, it might be, that the user doesn't have the IE9 or higher installed on his machine - so pls check this, as ProppFrexx uses the IE9 control internally.
Farbo
Post by Farbo »
Bernd, it helped, thank you!
Peter
