CD ripper
friso
CD ripper
Post by friso »
I'm at the moment ripping CD's from my collection to use in proppfrexx.
A couple of things bugging me.
First, after a rip the ripping console closes. You have to open it again. Is it possible to keep it opened?
The other thing is, that i have changed the output encoding to flac. After restarting the CD ripping plugin, it is back to mp3. Can this also be changed?
Thanx
Friso
Re: CD ripper
You might define the default CD Ripping settings within the general settings, see section 'Encoding/Recording'.
So simply change it there to an encoding profile of your choice, e.g. using FLAC - make sure to select FLAC as the default encoder within your encoding profile settings.
The CD Ripping dialog is closed on purpose, as it rips/encodes the tracks on-the-fly in the background to not block the application - it is not designed really designed for constant ripping tasks.
