music Libary-Play
grebda
music Libary-Play
Post by grebda »
Hello
I question whether it would not work when the song has finished playing, to be flicked to 30 minutes in the music library! Just that song in the music library will play out when struck! Sorry for my bad english !
SORRY FOR MY VERY BAD ENGLISH !! :-( :-(
Re: music Libary-Play
I am affraid I am not sure what you exactly mean.
Do you may be mean, that a certain track (once played) will not be played again within the next 30 minutes?
If yes, note, that this can be achieved by using the 'Global Song History' - see general settings, section 'Scripts/Scheduler' and click on the 'More Global Song History' button.
Also make sure to set the 'Global Song History' value to e.g. 50 tracks.
grebda
Post by grebda »
Hello, I'm sorry for my English worse! What I mean is that when the song has reached to the music library on 30 minutes struck
grebda
Post by grebda »
Or at least played song in the music library-database blush (red) to 30 minutes
I am affraid I still do not understand.
Can you try to explain that with more detail?
What do you mean by: "...when the song has reached to the music library on 30 minutes struck..."?
Is it some kind of history you are looking for?
Should a newly added track not be played again within 30 minutes?
grebda
Post by grebda »
SONG PLAYED! -> Reddens IN MUSIC LIBRARY! I'm sorry for my English, but I use Google Translate
Ahh, you want, that a track is marked as 'already played' within the Fin window as long as it is contained within the global song history?!
I guess that feature is possible to add to a next release.
What you can already do today is enable a certain history feature:
Go to general settings, section 'Scripts/Scheduler' and click on the 'More Global Song History' button.
And there enable the option 'Check Global History: Always' in the 'Conside manual added Tracks'!
When you now add a track from the Find window to the playlist which was already played - you will get a warning!
grebda
Post by grebda »
radio42 wrote:Ahh, you want, that a track is marked as 'already played' within the Fin window as long as it is contained within the global song history?!
Yes! That's what I thought! :)
The new v3.0.11.28 contains the required new option for the find window (allowing you to highlight find result entries matching the global song history).
See here for details: viewtopic.php?f=4&t=681
