Proppfrexx gives an error screen when shutdown the programm
friso
Post by friso »
Bernd
I have maild you that the issue was resolved by redesigning the windows in version .26. Now after a couple of shutdowns the problem is back again.
Going back to version .23 solves again the problem. There must be some changes made in the newer versions that causes this problem.
It only occurs when shutting down the programm
Re: Proppfrexx gives an error screen when shutdown the progr
Did you try the new .27?
The error was in the UI lib I am using and should be solved in v3.0.11.27.
Please send me your exact error.log to see what your problem is related to.
friso
Post by friso »
Yes now that i have installed the .27 version the error is gone
Thanx
