Playlist buggery after closing placeholder timer
djgait
Post by djgait »
I use placeholders in my playlists, A timer apperas when a plceholder comes by. When i close that timer, the playlist become very buggery.
There is no selection indicator. Blocks of tracks are displayed in white, The player indicator colors are not changed and eventuall you cannot select a track at all. Sometimes the whole playlist crashes and is displayed with a red cross in a white block.
All of the other functions are still working properly, and reloading the playlist solves the problem untill another placeholder comes by
The problems started from version 13, but still appear in the current version.
meisterpropper
Re: Playlist buggery after closing placeholder timer
Post by meisterpropper »
Same problem at my PFOA.
Please try the new v3.0.11.18 - which also contains an AAC/MP4 bug-fix with certain iTunes tracks having certain TAGs set, which might lead to a crash!
Now I see the issue - sorry for that!
It is now fixed with v3.0.11.19!
