Logs / Overlays
meisterpropper
Logs / Overlays
Post by meisterpropper »
within PFOA no logs and no errors are shown, if I use the ribbon "show log files". I´ve only empty files, but at the App-User folder the files aren´t empty.
At the Overlay Scheduler I´ve the problem, that no advertising slots are played out. At the log I found: no tracks found, but I´ve defined one track and assigned it to the advert slots. What could be wrong?
Re: Logs / Overlays
The log display issue has been fixed in v3.0.11.14.
However, the overlay/advert issue is not reproducable on my side.
Could it be, that you disabled the Advert-Partner or that your Campaign's valid to date now takes place?
The error message 'no track found' suggests that.
So please double check, that your advert campaigns are properly loaded and defined.
