v3.0.11.14 - stable
andre
Re: v3.0.11.13 - stable
Post by andre »
Great, thank you Bernd.
Farbo
Post by Farbo »
Great Bernd!
Peter
v3.0.11.14 - stable
Version 3.0.11.14 is out!
What's New?
  • Windows 8/.Net v4.5 compatibility bug-fix
  • Auto-Save GlobalHistory/Statistics added
  • Segue-Editor is now allowed to stay opened
  • New 'Auto-Update Segue-Editor' option added
  • Hooks are now available as a playlist column
  • New 'Use ReplayGain in ACPD' option added
  • Optimized UI speed (async processing)
  • New 'PlaylistLogFile' macros added
  • Restore of window layout optimized (in a chaned multi-monitor environment)
  • Optimized Look-Ahead read cache (when using slow devices)
  • AutoStart-Scheduler (UAC) bug-fix
  • DJ Playback ribbon buttons don't rewind bug-fix
  • Script-Line 'Command' bug-fix
  • Various other optimizations
  • Other smaller bug-fixes
  • stable
This version is finally fully compatible with the new .Net v4.5 Framework and as such with Windows 8.
The global song history as well as the global entry statistics is now automatically saved in the background every so often (actually with every 5 updates).
As such you should not loose any changes even in case of a machine crash (or at least only the last 5 updates).
The Segue-Editor window is now allowed to stay opened (and was redisigned to the new ribbon toolbar layout).
In addition a new 'Auto-Update Segue-Editor' option has been added, which further allows you to automatically track the currently selected track of the current playlist.
If that option is not enabled, you can manually update the Segue-Editor view.
A new playlist column has been added to show the hook cue-points of a track.
So far the ACDP (Automatic Cue Point Detection) was based on the original audio sample data not considering any ReplayGain value.
With the above new option enabled, ACDP now considers the track's ReplayGain value with its calculation, which should result in more accurate and comparable results.
A major task for this release was to even more decouple any processing tasks from the user interface (mainly within the playlist) for a more perfectly fluent and freeze-free UI at any time.
Restore of window layout optimized (in a changed multi-monitor environment)
In certain multi-monitor environments where the number of available screen changes over time or suddenly there was a chance to loose your current windows layout, resulting in disappeared panels. This has now been fixed.
When working with slower I/O devices (like USB harddisks) a new look ahead read cache has been introduced to minimize the chance of a stuttering audio output.
However, bear in mind, that in parallel, multi audio processing mostly the speed of your I/O devices is the bottleneck and not your CPU, as your I/O subsystem must be able to deliver the audio file data fast enough...
For the next release we again mostly focus on new features...
v3.0.11.14 fixes the bugs which have sadly been introduced with the v3.0.11.13!
Namely:
- window position restore
- initial cardwall exception
Andreas Duswald
Post by Andreas Duswald »
Hello Bernd
Now the sheduler is starting automaticaly again after start, thanks.
Sadly now there is a much bigger Proplem now. PF is just disapearing (crashing) within 30 minitus till 1 hour. The watcher is taking care, that it comes up again, but it is very unsatisfiing and frustrating, as of course the Program is interuptat, and if someone is moderating, than of course his Playlist is gone - I have checked the Errorlog, but there is nothing in it. PF is not logging the error
... the watcher has logged the carshes onle this way:
04.11.2012 08:30:10 WARNING: ProppFrexx ONAIR has terminated abnormally or was killed!
04.11.2012 08:30:10 INFO: Restarting C:\ProppFrexx ONAIR\ProppFrexx ONAIR.exe
Everything is possible ....
Andreas Duswald
Re: v3.0.11.14 - stable
Something else is also coming with the new Version. It crashes on some of the upcoming overlay, but not completly than, it is making a crazy noise and is not playing on anymore, the interface is freezed than.
This happens 2 ore three times a day. The complete crashes also about 2 times. so the station has to be checked now at least every three hours to enshure the automation is running on
If there are no errors in the "Error.log", please check your Windows Event log!
It might also be a Windows Update issue.
so make sure the latest Windows 'stuff' is properly installed and reboot your machine...
horacio muñoz
Post by horacio muñoz »
********** Error/Exception Information **********
Error Source: DevExpress.XtraTreeList.v12.1.System.Object GetValue(System.Object)
at DevExpress.XtraTreeList.Nodes.TreeListNode.GetValue(Object columnID)
at DevExpress.XtraTreeList.Nodes.TreeListNode.get_Item(Object columnID)
at ProppFrexx.a8.l(TreeListNode A_0)
at ProppFrexx.du.b()
at ProppFrexx.du.a(Object A_0, FormClosingEventArgs A_1)
at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
********** End **********
this appears when I start to refresh the list in the seque editor..thanks mr bernd
@horacio muñoz:
Can you please confirm which version you are using, as the error message doesn't belong to the latest v3.0.11.14!
@Andreas Duswald:
Please install the new v3.0.11.15! It fixes the crash in the audio engine you experianced (especially with the overlays).
