Segue Editor always opened
ykracht
Post by ykracht »
Hey Bernd
It would be a nice feature to have the ability to always ave the Segue Editor open with a save button as Dalet has.
So you can mix it easily. Would be nice to edit the selected song directly.
Re: Segue Editor always opened
Can you explain this in a bit more detail (what you actually want to achive)?
The Segue-Editor already has a save button (called 'Apply') and can be open at any time even in parallel to a playlist window.
So you can operate them in parallel: the Segue Editor and any other window.
TheoOrl45
Post by TheoOrl45 »
I think ykracht wants to see the "segue editor" in the main windows.
The goal : when current playing item changes, the segue editor shows, near from the playlist, the current segue without having to open it manually...
RCS Selector provides the user with this functionnality : segue mix is always visible at the bottom of the playlist, allowing users to move directly the audio "block" without opening any popup or windows.
PS : look at this picture : http://makingradio.co.uk/blogs/wp-conte ... 7/rcs4.jpg
The segue editor, at the bottom left, shows 2 blue blocks which are the current selected item and the next one. No need to open a new window to control the mix.
Be careful : in RCS, this area allows to move the block but not very precisely (for instance, no waveform is displayed) ! For a very precise mix (with waveform), users has to open the real segue editor window ...
Theo, from France.
ykracht
Post by ykracht »
Thanks for the quick reply, that the segue editor automaticly updates to the selected song, so you can dynamicly edit more songs. Like if you left-click a song, the segue editor updates the current song and the song next in the playlist
I guess I see what you mean!
I guess something might be added to allow (automatic updates of the Segue-Editor related to the currently selected playlist items).
The following options have been added to the new v3.0.11.13:
- Segue-Editor is now allowed to stay opened
- New 'Auto-Update Segue-Editor' option added
