proppfrexx tagger error
I use Proppfrexx Tagger to inspect tags.
After installing VS2012 express it does not start any more :
********** Error/Exception Information **********
Error Message: Could not load file or assembly 'BASS_NFX.dll' or one of its dependencies. The specified module could not be found.
Error Type: System.IO.FileNotFoundException
Error Source: Bass.Net.Int32 BASS_NFX_GetVersion()
   at Un4seen.Bass.AddOn.Nfx.BassNfx.BASS_NFX_GetVersion()
   at ProppFrexx.b5.e()
   at ProppFrexx.cf.i(Object A_0, EventArgs A_1)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at DevExpress.XtraEditors.XtraForm.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
********** End **********
Re: proppfrexx tagger error
Just now I 've read that proppfrexx does not support .net v4.5
No problem I can wait for a future fix.
I think that Full .Net v4.5 is installed with vs2012 express.
However I reinstalled (in fact repaired) .Net v4.5 from the standalone file "dotnetfx45_full_x86_x64.exe" found at microsoft's site.
Do you have any other FULL .Net v4.5 link ?
That exception still raises.
I'll take a look at it.
The download link is the correct one...maybe something broken in the last version regarding v4.5?
ProppFrexx supports the .Net v4.5 framework.
However, you must install the FULL .Net v4.5 framework or have the Full v4.0 framework installed as well.
As a quick workaround:
Copy the file "basswma.dll" from the "AddOn" sub-folder to the main installation folder.
I can now reproduce the issue.
I'll post a fix soon!
