PFOA Time.exe launching outside screens
Adger
Post by Adger »
Since the last update of PFOA my installation of PFOA-time (which I am launching by means of a link inside my autostart folder) is starting outside the visible range of my screens. How can I make it "come back"?
Adger
Re: PFOA Time.exe launching outside screens
Post by Adger »
I have set PFOA to "automatically check for updates" on launch and it informed me about the latest update (.12, I guess). I manually quit pf-time.exe, installed the update and that's it. Next time pf-time was launched by means of autostart folder, it was sent beyond the limits of my screen.
The "ProppFrexx Time" application stores its config values inside the Windows Registry.
See "HKEY_CURRENT_USER\Software\radio42\ProppFrexx Time\LAYOUT".
The positions are kept in the following keys:
- "ClockLeftPos"
- "ClockTopPos"
- "ClockWidth"
- "ClockHeight"
- "ClockIsMaximized"
So you might edit those values manually via the 'regedit' tool.
However, it is strange, that the positions might have changed!
Have you updated a display driver or changed your monitor layout?
Since in the latest version nothing was changed within the "ProppFrexx Time" application.
