v3.0.11.12 - stable
v3.0.11.12 - stable
Verison 3.0.11.11 is out!
What's New?
  • Global History check enhanced for manualy added Tracks
  • TalkUser functionality enhanced
  • VST save/restore parameters optimized
  • Weather API changed to WorldWeatherOnline
  • Mixer-Channels restore Recording-Output-Folder
  • OPUS audio codec support added
  • Optimized file stream buffering
  • Playlist entry Drag&Drop using CTRL doesn't eject player
  • Icecast Force Title-Update bug-fix
  • Find-Window bug-fix (Trackname display)
  • First .Net v4.5 compatibility release
  • Various other optimizations
  • Other smaller bug-fixes
  • stable
Global History check enhanced for manualy added Tracks:
The global song history now offers new configuration options to 'Consider manual added Tracks':
Add to Global History:
Select if tracks manually added to a playlist should be added to the global song history.
None: Tracks manually added will never be added to the global song history.
Only At AutoPlay: Tracks manually added will only be added to the global song history if AutoPlay is ON.
Only At Scripting: Tracks manually added will only be added to the global song history if the resp. playlist is currently running in scripting mode.
Always: Tracks manually added will always be added to the global song history.
Remove with Playback History:
If checked and you are removing a track from the playback history, that track will also be removed from the global history - else it will just be removed from the playback history.
Check Global History:
Select if tracks manually added to a playlist should be checked against the global song history.
None: Tracks manually added will never be checked.
Only At AutoPlay: Tracks manually added will only be checked if AutoPlay is ON.
Only At Scripting: Tracks manually added will only be checked if the resp. playlist is currently running in scripting mode.
Always: Tracks manually added will always be checked.
Ask for detected Duplicates:
If checked and a track manually added to a playlist will fail the global history check, you will be asked to add this track anyhow - else adding such track will fail siliently.
The TalkUser functionality has be enhanced by the following options:
TalkUser Type:
Defines the type of the TalkUser action.
Regular: The TalkUser button acts as a regular button and must be clicked once to be activated and clicked again to be deactivated.
Push To Talk: The TalkUser function is only active while the button is pressed and deactivated once the button is released.
3-State: The TalkUser button acts in 3 states. The 1st click activates TalkUser, the 2nd click issues the 'Play Next Track' action and the 3rd click deactivates TalkUser.
Stop Playlist (AutoPlay):
If checked AutoPlay will be turned OFF for the current playlist during talk over.
At TalkUser ON: AutoPlay OFF
At TalkUser OFF: AutoPlay ON (if turn off beforehand)
A seperate options allows you to specify an addition track action:
Do Nothing: No additional is carried out.
Pause the current playing Track: If a current track is playing it will be paused at the current position and resumed from there.
Eject the current playing Track: If a current track is playing it will be stopped and ejected.
Soundbed Play Condition:
Defined the condition when the soundbed should be played resp. started.
Never: The defined soundbed will never be played.
At Track End: If the current playlist is currenty playing, the soundbed will be started once the current track ends. If the current playlist is not playing it is started immediately.*
Only if Playlist is NOT playing: The soundbed will only be started when the current playlist is not currenty playing.*
Always: The soundbed will always be played and started immediately.
*In case you selected the 'Stop Playlist during Talkover' option, the soundbed will be started immediately regardless.
andre
Re: v3.0.11.12 - stable
Post by andre »
Verry nice Bernd, thank You.
Farbo
Post by Farbo »
Great Bernd, I will try especially TalkUser functions. :-)
Peter
DirkB
Post by DirkB »
I have a question, is the OPUS codec meant for streaming with IceCast?
I was looking in the encoder section but did not find it.
Regards,
Dirk
Farbo
Post by Farbo »
Bernd, could you also get back the CTRL+talkuser for turning off bed track? Now when talkuser is turned on and I want to stop bed I just have to turn off talkuser.
Peter
That was never removed. It is still there.
So what is the issue with it and if, what are your exact TalkUser settings?
Farbo
Post by Farbo »
My settings are as on printscreen. But if I click on TalkUser and afterwards to manually stop bed tracking playing and start playlist item (which has ramp defined) I try to press CTRL+TalkUser button but bed track is not stopped but rather whole TalkUser is turned off, i.e. Autoplay is turned on and master fader goes up, mic input is closed. I remember that with CTRL+TalkUser was just for stopping bed track defined in TalkUser.
Peter
Farbo
Post by Farbo »
That´s what I meant, thank you Bernd. And sorry, forgot to attache that printscrreen.
Peter
Farbo
Post by Farbo »
Thank you Bernd, I will try it. Am I blind? I did not see this. :-( Have a nice weekend.
Peter
Note, that you can use the new 3-State type in your case I guess:
1st click: Start TalkUser (e.g. AutoPlay=OFF, unmute MIC, attenuate outputs, play Soundbed).
2nd click: PlayNext Track (i.e. stop Soundbed)
3rd click: Stop TalkUser (e.g. AutoPlay=ON, mute MIC, full-level outputs).
