mass remove replay gain values
Farbo
Post by Farbo »
Is it possible to remove replay gain values for 120 tracks at one time without having to remove ACPD points?
Peter
Re: mass remove replay gain values
ACPD is NOT related to ReplayGain!
However, no, currently you can only recalculate the ReplainGain values for all selected tracks OR remove the ReplayGain value per single track - but mass remove ReplayGain values.
Not sure, if that is really needed, as you either want to have RG enabled (in which case RG values are needed) or you might disable the use of RG completely in the general settings.
Farbo
Post by Farbo »
I disabled it better. Because I am using broadcast VST plugin which should already hold the same volume level for all tracks.
Peter
