Special media entries font colour
Farbo
Post by Farbo »
Is it possible to define exact font/text colour? For example for jingles I defined red colour for font/text. As you can see from printscreen only track number in playlist is red but the rest of playlist item font has black colour. Is it because it is fixtime element or is there another reason?
playlist item colour.jpg (38.18 KiB) Viewed 10402 times
Peter
Re: Special media entries font colour
You can adjust the color for each media entry type individually.
The media entry type colors can be defined in the general settings dialog (section 'Playlist/Others' by clicking on the 'MediaType Colors' button - same as for the cardwalls).
When defined they will be used within a playlist window for the 'Player' and '#' columns!
Other columns are not supported to ensure 'readability'.
Setting the font individually per media entry type isn't supported - but you can enlarge the Font in general by using the 'Big Font' option in the 'User Settings'.
This behaviour can also not be changed, as the general font and text colors are defined by the resp. selected 'Skin'.
TheoOrl45
Post by TheoOrl45 »
Regarding the media entry type, is it possible to define specific icons for "jingles", "music" and so on ?
I'm not in front of ProppFrexx at the moment and so, I didn't search by myself if it's possible... I take this opportunity of the previous question to ask you about the icons customisation.
The "star" icon for jingle is not very "sexy"... :-)
Theo, from France.
No, currently the media entry type names and icons are fixed and can not be customized.
szal77
Post by szal77 »
Erm… and this has got exactly what to do with font colours?
