Starting PF bug
Farbo
Starting PF bug
Post by Farbo »
Bernd, when I updated Microsoft net framework and started PF, the following error occured:
********** Error/Exception Information **********
Error Message: Could not load file or assembly 'BASS_NFX.dll' or one of its dependencies. The specified module could not be found.
Error Type: System.IO.FileNotFoundException
Error Source: Bass.Net.Int32 BASS_NFX_GetVersion()
at Un4seen.Bass.AddOn.Nfx.BassNfx.BASS_NFX_GetVersion()
at ProppFrexx.f2.ad()
at ProppFrexx.cv.ag(Object A_0, EventArgs A_1)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at DevExpress.XtraEditors.XtraForm.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
********** End **********
Peter
Farbo
Re: Starting PF bug
Post by Farbo »
So shall I download only version 4? Can you provide me the concrete link for download?
Peter
Farbo
Re: Starting PF bug
Post by Farbo »
I did update to 4.5 :-( Ok, I am trying to reinstal framework to correct version.
Peter
Farbo
Re: Starting PF bug
Post by Farbo »
It is working now with version 4.
Peter
Re: Starting PF bug
To which .Net Framework did you update?
Note, that the Full .Net v4.0 Framework is needed.
The v4.5 Framework is currently not compatible when using the new WinRT API.
Re: Starting PF bug
It is given in the User Manual.
On the Microsoft Web Site select the Full v4.0 .Net Framework, just as sais in the manual.
However, you did not anser my question above...
