Object reference not set to an instance of an object
Adger
Post by Adger »
(3.0.11.10)
I tried to use Easy-Q 11.04 (parametric EQ VST, http://www.rs-met.com/) and PFOA threw the following error:
********** Error/Exception Information **********
Error Source: DevExpress.XtraEditors.v12.1.Void AddRange(System.Object[])
at DevExpress.XtraEditors.Controls.ComboBoxItemCollection.AddRange(Object[] items)
at ProppFrexx.dt.e(Boolean A_0)
at ProppFrexx.dt.h(Object A_0, CancelEventArgs A_1)
at DevExpress.XtraEditors.Repository.RepositoryItemPopupBase.RaiseQueryPopUp(CancelEventArgs e)
at DevExpress.XtraEditors.PopupBaseEdit.ShowPopup()
at DevExpress.XtraEditors.PopupContainerEdit.ShowPopup()
at DevExpress.XtraEditors.PopupBaseEdit.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at DevExpress.XtraEditors.TextEdit.WndProc(Message& msg)
********** End **********
This in itself would not pose much of a problem. But having that VST installed and trying to start PFOA the error prevents PFOA from starting at all. I had to forcefully kill PFOA by means of the Taskmanager. When trying to restart PFOA again the errormessage appeared. This unexpected interruption / freeze should be addressed, I think.
Adger
Re: Object reference not set to an instance of an object
Post by Adger »
(moved reply this to Q&A)
I'll see what I can do with this VST...
Should be fixed with v3.0.11.11.
