UI Alignment Issue in TAG Editor Form (Tab Control)
rascas
Post by rascas »
Hello, Sir!
In the 'TAG Editor' form, I found a minor UI alignment issue with the controls on the tab control. Windows 11 Pro 25H2
Tested on another workstation: Windows 10 Pro 22H2 same behavior.
ProppFrexx ONAIR 4.3.5.1 (DevExpress Dark Style skin)
It looks like the issue only occurs with certain skins.
I have attached a video
A video from YouTube usually appears here. Please contact an administrator.
Due to the 10-URL limit per post and the lack of a `[spoiler]` tag, I can't post a full list with screenshots here, but I'll leave a list where the problematic skins are marked with an exclamation mark '!':
Skin style: Total 59
Standard skins - 25
Bonus skins - 26
  • ! Black
    ! Blue
    ! Caramel
    Coffee
    ! Dark Side
    Darkroom
    Foggy
    ! Glass Oceans
    High Contrast (classic)
    ! iMaginary
    ! Lilian
    Liquid Sky
    London Liquid Sky
    Metropolis
    Metropolis Dark
    Money Twins
    ! Office 2007 Black
    ! Office 2007 Blue
    ! Office 2007 Green
    ! Office 2007 Pink
    ! Office 2007 Silver
    ! Seven
    Sharp
    Sharp Plus
    ! Stardust
    ! The Asphalt World
Theme skins - 8
  • ! Pumpkin
    ! Springtime
    ! Summer
    ! Valentine
    ! Xmas (Blue)
    McSkin
    ! Blueprint
    ! Whiteprint
Re: UI Alignment Issue in TAG Editor Form (Tab Control)
Some Themes are using a slightly 'thicker' borders. As such, it appears, that in the TAG Editor (which has many input fields) the right border is slightly (1-2 pixel) closer to the right edge of this fixed dialog.
But this is a very very minor 'design' issue without any functional effect or restriction at all.
This is NOT a bug at all. Or please describe, where you are restricted or experience any bug?
rascas
Post by rascas »
Thank you for the prompt reply. I completely agree with you—this does not restrict any functionality or break the workflow. It is indeed a cosmetic design anomaly rather than a technical blocking bug.
The reason I brought it to your attention is purely about the "fit and finish" of the software. Here is why I believe reporting these minor UI details is valuable:
1. Professional Polish: ProppFrexx is a premium, highly respected broadcasting automation tool. Pixel-perfect UI alignment matches the high standard of the software's powerful audio and routing engines. When borders are clipped, asymmetric, or look like a rendering error, it slightly detracts from that premium feel.
2. Visual Ergonomics: Managing large music libraries means users (including myself) spend hours meticulously working inside the TAG Editor. Even a 1-2 pixel misalignment or a cut-off border creates subtle visual tension and visual clutter. A clean, perfectly aligned interface significantly reduces eye strain during long cataloging sessions.
3. Constructive Contribution: As a dedicated user, my goal is simply to help make the software as perfect as possible on all fronts. I completely understand this is not a high-priority fix. I reported it so it could perhaps be added to a low-priority backlog for future UI polish.
I appreciate your hard work and time. If this is an unavoidable limitation of the underlying UI framework when rendering specific Windows themes, I completely understand!
Fixed in v4.5.3.2
